Is Using PTFE After WD40 a Good Idea?
kieran40075
by kieran40075 » Mon Apr 29, 2019 1:32 am
Like an idiot, I recently 'lubricated' some locks with WD40 before learning that this isn't a good idea. I'm now planning on using a PTFE spray on the same locks (I was going to go with GT85), but will this work on a lock that's recently been sprayed with WD40, or will it just make it worse? Should I maybe wait a while before using the PTFE?
silverfox56
Re: Is Using PTFE After WD40 a Good Idea?
by silverfox56 » Mon Apr 29, 2019 10:25 am
Are you talking about a Yale lock or similar and you are lubricating the part of the lock where the key goes in ? If so, yes, I'd leave it for a while. Often graphite powder is the suggested lubricant.
kieran40075
by kieran40075 » Mon Apr 29, 2019 4:37 pm
silverfox56 wrote:Are you talking about a Yale lock or similar and you are lubricating the part of the lock where the key goes in ? If so, yes, I'd leave it for a while. Often graphite powder is the suggested lubricant.
I've used the WD40 in the keyhole of a UPVC door (so a Euro lock I guess?), and also in the handles and latch mechanism. And I've also used it in the handles and latch of a few non-locking internal doors.
I've heard about graphite but it seems a bit messy, and I've read that if you've already used WD40 the graphite will just get gummed up in it. So I was hoping that a non-dry PTFE spray would penetrate through the WD40 better; I've seen plenty of sources online that recommend PTFE for locks.
Brendan2010
by Brendan2010 » Fri May 10, 2019 11:48 am
I agree best to wait a while and let the WD40 ware off a bit. I had same issue and used DURA-SLIP PTFE spray which worked really well
It is currently Thu Oct 31, 2024 6:20 pm
