Bosch Junior 28i Compatibility With Salus Wireless Receiver
Phattanglo
by Phattanglo » Mon Apr 29, 2019 8:10 pm
I have a holiday home which is fitted with a circa 2009 Worcester junior 28i.
Could anyone please confirm if a Salus wireless receiver for a current greenStar 28i junior is compatible.
Cheers Kev.
Re: Bosch Junior 28i Compatibility With Salus Wireless Receiver
by htg engineer » Fri Jun 21, 2019 9:27 pm
Shouldn't be an issue, a boiler needs an electrical supply and the programmer is just an on/off switch.
Unless they have some obscure internal controls, which can be linked out, any programmer will work.
The only issue is if you buy a single or twin channel, as a combi only needs a programmer for heating, you only want a single channel, and a permanent supply for the hot water to work.
It is currently Fri Nov 29, 2024 3:55 pm
