Everything pointed to not until I took away the door frame... Basically I have a separate toilet & bathroom I want to knock through. The wall itself is some very thin black blocks that is built on top of the floor boards. In the loft, the joists run the same way as the wall.
However, after taking out the door frames, some timber 'supports' are running about 1/3rd of the way down that have been cut in to the blocks and stick out about 2 inches in to the loft and are nailed in to the beams above?
I hope some of that makes sense, but I am now unsure if these are supports or for something else?
