Advice Needed on Painting a Window Recess
Leannew
by Leannew » Thu May 02, 2019 10:54 pm
Can anyone offer advice on how to paint a window reveal? Should I paint the reveal before painting the wall?
thedoctor
Re: Advice Needed on Painting a Window Recess
by thedoctor » Fri May 03, 2019 8:44 am
If you are glossing the reveal, probably best to paint your walls and then do any gloss work required
Kind Regards
Leannew
by Leannew » Fri May 03, 2019 10:07 am
Thank you for your response. I'm not sure if I used the correct terminology. It's the recessed bit of wall to the side and top of the windows that I'm enquiring about. I will gloss the cill after painting the walls.
thedoctor
by thedoctor » Sat May 04, 2019 8:55 pm
Apologies, should have made it a bit clearer - If you are keeping the surrounding wall and reveal the same colours then generally you would paint the window reveals first and any other reveals, doorways, alcoves etc and then the walls
If they are going to be different colours then best to paint wall first and then do the reveal so that you get a nice crisp finishing edge to the reveal.
Hope this helps
It is currently Fri Nov 22, 2024 4:58 pm
