What Varnish is Hard Enough to Reduce Cat Scratching Damage?
Windinherhair
by Windinherhair » Fri May 03, 2019 5:27 pm
I am in the process of removing wallpaper from our upstairs hall, high-ceiling stairs, dining room, and front door area (all open plan) due to our 4 year old cat shredding the walls. This is in preparation for skimming, which I'm told should deter her.
She has also been dragging her claws down the door surrounds. I was thinking to coat these with an extra tough varnish. Can anyone recommend a varnish for this purpose? Would it be an idea to use a yacht varnish, or maybe a floor varnish? I don't really care if it's overkill, just as long as it stops her from destroying them!
Thanks in advance, from one frazzled cat owner.
anthony martin
Re: What Varnish is Hard Enough to Reduce Cat Scratching Damage?
by anthony martin » Sat May 04, 2019 11:35 am
Moisture curing Polyuraphane varnish, available from shipley paint bradford. ps sets immediately you have to work quick, throw brush away after use, sets rock hard on any surface, it does change colour in time nice rich light brown.
It is currently Mon Nov 25, 2024 2:36 pm
