Problems Connecting Toilet Flush Valve to Mains Supply
Krafty81
by Krafty81 » Tue May 07, 2019 10:37 am
Hi. Looking for some hopefully very simply advice. I needed to replace a side entry flush valve on an enclosed toilet. I have installed the new flush valve but am having problems connecting it to the mains water supply pipe. The flush valve is 1/2" and pipe is threaded. The mains supply has a corner fitting with a push valve. I think its 15mm. I am guessing I need some form of connector which will fit the mains push valve and also connect to the threaded flush valve pipe - but I just dont know what I actually need. Any help/advice would be really appreciated.
It is currently Thu Dec 05, 2024 2:51 am
