Fixing 900mm Exterior Post to Breeze Block
fidaleo
by fidaleo » Wed May 08, 2019 9:14 pm
I have an existing patio with balustrade round the perimeter attached to 900 mm square wooden posts.which appear bolted to breeze block base
The post is to be attached to a breeze block wall to extend the balustrade
The bolts have M12 written on them but I'm unsure if the M12 fixing used goes into a masonry plug or are concrete bolts which don't require a plug.
I have never attached to breeze block so unsure but wondered if these would do the trick.
https://www.amazon.co.uk/Concrete-Tappi ... diy&sr=1-7
Any advice would be appreciated
Regards
Martyn
fidaleo
Re: Fixing 900mm Exterior Post to Breeze Block
by fidaleo » Thu May 09, 2019 12:13 am
fidaleo
Re: Fixing 90mm Exterior Post to Breeze Block
by fidaleo » Thu May 09, 2019 12:17 am
correction posts are 90 x 90 mm
It is currently Thu Nov 21, 2024 7:39 pm
