Fixing Wall Hung Vanity Unit but Holes too big
Teessider66
by Teessider66 » Tue May 28, 2019 4:38 pm
Any help greatly appreciated ....
I am hanging a wall hung vanity unit in the bathroom.
The wall is plasterboard, covered with 11mm MDF
I installed a frame in the wall, using the existing metal stud walls intending to screw through into them. It now turns out that the frame is 3" too high and when I drill through the MDF and plasterboard there appeared to be space behind. As the unit is quite heavy I bought some snap toggles and drilled 13mm hole for them. I then hit what I think is the metal studding behind, though it is a bit deeper than I expected.
I now have 13mm holes through the MDF and plasterboard and the metal frame behind.
What are my best options for fixing the unit to the wall?
It is currently Thu Dec 05, 2024 3:19 am
