Concrete Lintel Found Above Wardrobe
Misty14
by Misty14 » Thu May 30, 2019 5:56 am
Hi everyone I’ve hit a bit of a snag, we are in the process of removing a 1950s old council flat block built wardrobe that had a 2 door timber frame in the corner of the room after collapsing the frame discovered it has a concrete lintel above sitting across the top. I have looked in the loft and there are no walls above it and don’t seem to be any joists directly in line where it is siting below can anyone help at all with any idea if it is supporting or not thanks.
It is currently Sun Dec 22, 2024 10:42 am
