Misaligned Kitchen Mono Block Tap on Reginox Single Bowl
fix4Freedom!
by fix4Freedom! » Fri May 31, 2019 9:16 am
I just had a new kitchen worktop, Reginox single bowl sink and mono block tap fitted, which is great - except for the fact that the tap lists a little to the right, completely ruining the effect. Is there a way that the mono block base can be raised on the right hand side to set it straight, or do I have to replace the sink, which slopes towards the bowl where the tap holes are situated and is the cause of the misalignment? Thanks for responding.
It is currently Wed Dec 25, 2024 3:52 pm
