Double Glazing Window Hinge to fit Standard UPVC Window
petel
by petel » Sun Jun 09, 2019 11:03 am
Hello.
Can anyone please advise, if they are aware of window hinges to fit standard UPVC
double glazing which once the window is opened, will then allow the window to slide out farther
than the normal fixed units available on Ebay and others?
I seek to open the window, then slide it out by a further 2 to 3 inches, in order to be able to swing it
through 180 degrees, clean the outside then reverse the procedure to re close.
I understand that this type of system is available widely in Europe ( especially on commercial
buildings, hotels etc, etc ) though it may be on a different design of window and frame.
Any pointers would be much appreciated.
Thank you, Pete.
It is currently Thu Nov 28, 2024 5:53 pm
