Tar Flat Roof Leaking Badly - Cromapol Used Previously
ccc120
by ccc120 » Tue Jun 11, 2019 2:10 pm
If I use the Britannia Aquashield High Build, https://www.rawlinspaints.com/home/...n ... build.html, as some gaps/holes could be wider than 3mm, which cheap scrim / alternative could I use under the paint?
Could I paint, put scrim then paint again?
Or should I use the two items below instead:
[​IMG]Acrypol + Waterproofing - Grey 2.5Kg
and
Acrypol Flexible Reinforcement Scrim Tape - 150Mm X 20M
It is currently Mon Dec 02, 2024 1:03 pm
