Front Door Sticking on 3 Year old Property
jonesthemuso
by jonesthemuso » Wed Jun 12, 2019 9:40 pm
Hi all,
Noticed the other day that my Front Door in a 3 year old property has started to stick.
the bottom left hand corner hits the frame when closing (from the prospective of below photo) and has to be pushed a little to sit in the frame.
My first thought was just that the hinges need aligning better but on inspection im not sure that would help. If you look at the picture below of the door you can see that both bottom corners seem to be wider/closer to the frame than the top corners. This would imply that its not a singly hinge thats out of alignment? IS the door itself warped?
Any ideas on a quick fix or advice on what to try.
PHOTO AT BELOW LINK
https://www.dropbox.com/s/xuvqogsy2iake ... .jpeg?dl=0
It is currently Sun Dec 22, 2024 8:27 pm
