External Damproof for House Wall Below Ground Level
GDiy
by GDiy » Tue Jul 02, 2019 3:11 pm
Hi all,
I'm building a retaining wall (gabion) that, when back filled, will result in a section of my house wall being underground. The external wall is rendered (bit damaged but i'm fixing that). Will render alone suffice if its now underground to prevent damp getting in, or do I need to be doing something else?
Its impossible for me to tell what sort of damp proofing has been undertaken inside the house without ripping out panelling. Any advice is much appreciated.
DIYQueen
Re: External Damproof for House Wall Below Ground Level
by DIYQueen » Thu Sep 05, 2019 3:53 pm
No you can not! If you connect your house to anything that is below ground level without proper damp proofing you asking for a big problem. Water will travel up via capillary action from the ground into your wall and into your home. If you want to understand more this is a basic explanation - find the bit about bridging.
DIYQueen
by DIYQueen » Thu Sep 05, 2019 5:55 pm
Sorry, I posted a link with an explanation but it has been removed. Just do a google search for rising damp and bridging.
It is currently Sat Nov 23, 2024 7:21 am
