Using MDF Instead of Chipboard on Roof?
satinseat
by satinseat » Wed Jul 03, 2019 12:07 pm
bought 18mm mdf instead of chipboard. can I use it please as its heavier?
thanks
ian
slo101
Re: Using MDF Instead of Chipboard on Roof?
by slo101 » Sun Mar 29, 2020 10:51 pm
I don't know how you are using it so it hard to give a definite answer but...
Chipboard is preferred as MDF is very sensitive to water. if it gets wet it will blow apart, whereas the resin in chipboard (or OSB oriented strand board) makes it better at resisting water.
Ideally if the water proof covering is fitted properly water should never come into contact with the board. However, if it does you will be glad that the chipboard is there, as you will be able to find and fix the leak, without tearing up your whole roof.
It is currently Thu Nov 21, 2024 11:32 pm
