Portacabin as a (very) temporary 'video diary-room' booth?
portacabin blues
by portacabin blues » Thu Sep 06, 2007 8:22 pm
I need to transform a 3 x 3m room within a site portacabin into a booth suitable for conducting video interviews. The surroundings will be fairly busy with crowd-noise, and the unit contains a "low noise" generator (though this obviously isn't in the same 'room' that we'll use for filming).
If that isn't enough, my set-up time will be a mere matter of hours.
Is there a solution that can do anything to reduce noise coming into the cabin to a minimum, or am I barking up the wrong tree (so to speak).
Any suggestions gratefully received.
Nimrod
by Nimrod » Fri Sep 07, 2007 8:59 pm
Woof! Woof!
What an interesting challenge. There are a number of points to consider.
Airborne noise coming into the room. Use masking tape over any cracks into the room. Round windows and doors. The aim is to seal any cracks and make them air tight.
Structure borne noise. Given your circumstances there is not much you can do here. Perhaps explain to people using adjoining rooms what you're doing, tell them when you're doing your interviews, and ask them 'to run silent'.
Close mic-ing will help overcome problems associated with small rooms.
Hope this helps.
It is currently Sun Dec 22, 2024 2:02 pm
