Wiring up a new Security Light Using Existing Wires
Jailhouse
by Jailhouse » Thu Jul 11, 2019 8:46 am
I have a wall with wires coming out of it ...
These wires are connected to a switch on the other side.
There are 2 brown wires, 2 blue wires, and one earth wire.
I want to connect a security light to these wires.
What kind of security light would I need to buy in order for it to be compatible with these wires?
I know from the previous installation that the 2 brown wires terminated in one plastic block left to do nothing.
So does that affect the kind of light I buy or should I connect the brown wires somewhere in the new light?
Appreciate the help,
JH
Re: Wiring up a new Security Light Using Existing Wires
by Mr White » Thu Jul 11, 2019 7:45 pm
It is your choice of which light you choose to install.
It should be connected the same way it was prior to the old light being removed.
Jailhouse
by Jailhouse » Thu Jul 11, 2019 9:37 pm
How do I know if the new light will be able to take the wires from my wall?
For example, here is a light I am considering...
Will it take the wires from my wall?
JH
It is currently Sat Jan 11, 2025 2:46 pm
