Can I Remove a Continuous Internal Wall on Ground Floor and Upper Floor?
DIY-Si
by DIY-Si » Thu Jul 18, 2019 7:51 am
I'm looking at a property that's on the market and I have a question about structural engineering.
Within the house there is a 3.16m wall (separating dining room and sun lounge/parlour). Directly above this is another wall separating two upstairs rooms.
The wall in the dining room already has a sliding door in it (approx 2.5m across) so I'm assuming there is already a supporting beam in place above it.
My question is: If I wanted to remove both walls (IE to open out dining room plus sun lounge into one room, and open out the two upstairs rooms into one room) is this possible hypothetically?
Obviously I'll get in a structural engineer to make a final decision and calculate the correct size of beams etc but I just wondered if it's even possible to do this...
robshort18
Re: Can I Remove a Continuous Internal Wall on Ground Floor and Upper Floor?
by robshort18 » Thu Jul 18, 2019 11:37 am
I should imagine it is possible.
However, cannot possibly answer this properly since we don't know if it's a structurally integral wall.
I'm imagining that will probably be an issue for you. Finding out the walls are structurally integral...
It is currently Fri Nov 22, 2024 4:54 am
