building on existing patio
60minuteman
by 60minuteman » Fri Sep 07, 2007 4:25 pm
I have a block patio and it slops quite badly 5m x 6m. I wish to build a deck and an L shaped seating area out of blocks which will then be rendered and painted. Should I dig the patio up first and dig foundation trenches? or should i level it out and use it as the foundations?
loomo
by loomo » Sun Sep 09, 2007 7:56 am
yeah dig it up and put a foundation in. just dig it down till you get to a stable footing and obviously making it wide enough for the blockwork. leave a bit of scarcement either side,ie, if it's nine inch block then have four inch of concrete remaining either side.
thedoctor
by thedoctor » Sun Sep 09, 2007 11:10 am
See our project on foundations to get the principle here. The job will only be as good as its foundation.
It is currently Sat Nov 16, 2024 12:33 am
