Replacing Broken Side bed Rail
mike_bike_kite
by mike_bike_kite » Sun Aug 18, 2019 10:20 am
The rail on my bed that runs along the side of the bed between the two upright posts has broken. It turned out to be made of MDF surrounded by oak veneer but I quite like the bed and wondered whether I could replace the broken piece. The upright has two large bolts coming out which fit through two holes in the rail and the nut is tightened through a larger hole in the rail where the nut comes out.
The closest thing I can find to illustrate it is this: https://www.pinterest.co.uk/pin/563231497128194202/
A similar bed is this one (The break on my bed is near where the pile of books are on the floor): https://www.dreams.co.uk/moore-wooden-b ... /221-00209
My thoughts were:
  • 1) Cut a new length of wood to match the old rail.
  • 2) Cut holes for the bolts.
  • 3) Cut larger holes for the nut and hope it all matches up.
  • 4) Join another smaller length to hold the sprung base and then both glue it and dowel joint it to the first length of wood.
  • 5) If all this works then I'd have a go at adding an oak veneer afterwards.
Is this the right approach?
Too much work for a below average wood worker?
What's the name of this joint used?
Thanks for reading
Mike
It is currently Fri Nov 22, 2024 3:52 pm
