by ericmark »
Mon Aug 26, 2019 3:17 pm
We have a set of rules designed to keep things safe. Some have nothing really to do with the electric part, but tell you switch heights and safe routes, and if everyone uses safe routes, then we know where we can put a screw without hitting cables.
There is nothing wrong with using flex, but things like maintenance free junction boxes don't work well with flex, but some basic rules are you should not be able to access a live part without the use of a key or tool, with the exception of the ceiling rose and pendent lamp holder which tradition has allowed one to access by hand, although there are now shuttered versions of the BA22d lamp holder where you can't poke your finger in and get a shock.
One of the big problems is although some thing fitted in 1950 complying with the rules at the time can be left as it is, once you add to it, then it must comply with todays regulations, so before I can fit a new socket, I have to insure the supply is RCD protected, but the old one can remain without it.
Also running cables one now have to consider what happens in a fire, use of plastic clips is OK as long as if all those clips melt, the wires will not fall on any firemen. So inside trunking we now have to fit metal clips every so often so cables can't fall, where 10 years ago we could fit plastic sticky back trunking and use some decorators chalk which once dry would stop it falling off again.
As to which bits Mr White was looking at I don't know. And since it was work in progress it may be OK now, but insulation tape can be removed without a tool, so we have to use little plastic boxes with a small screw to hold lid shut so a tool is required to access live parts.
