Electric Shower Supply fed from Cold tap Supply?
iphammer
by iphammer » Thu Sep 05, 2019 11:24 pm
I have recently bought a 2 bed ex council flat. In the kitchen I have a combi boiler. By the looks of it there use to be a hot water cyclinder in the airing cupboard which has been discounted and pipes blanked off ( it looks a mess) there is also a water tank in the loft which is empty.
Under the bath tub there is plastic pipe connected to cooper pipe and then a flexible hose going onto the taps. Is this ok?
The tap has a shower connection aswell which I’m thinking of changing.
I’d ideally like to fit a new bathroom and do away with the bath tub and have a shower instead as space is limited but with my budget being low I doubt I’d be able to afford a new one.
If I were to install an electric shower can I connect off the cold tap supply for the shower or not ?
collectors
Re: Electric Shower Supply fed from Cold tap Supply?
by collectors » Thu Sep 12, 2019 3:08 pm
If you have a combi you can take you shower of the hot & cold that comes into the bathroom. But make sure you buy a shower suitable to your combi make & model. If you want an electric shower, you would have to make sure the cold water is mains pressure in the bathroom, & in preference go for the 10.5kw as electric showers struggle in the UK winter with the water getting colder. This will entail a 10mm TWE cable to run it, direct from the fuse board.
It is currently Wed Dec 25, 2024 5:44 pm
