Removing Surface-Mounted Socket from Skirting
PieOfSauron
by PieOfSauron » Wed Sep 11, 2019 10:55 pm
This is my first post and, as it relates to electrical wiring, I hope it's not my last.
I would like to remove a 2-gang surface mounted socket box that protrudes from the skirting in a bedroom, in order to place a wardrobe against the wall. I know I need to be isolating the circuit, fitting terminal blocks to the cores and covering with a blanking plate, but I know there'll be more to it than this.
I have this Saturday set-aside to sort out the socket and then build the wardrobe and get it in place. I have not yet removed the socket box to inspect behind it. I will have to do this on the Saturday morning. I live close to a Wickes so can pop out and get anything else I need.
So my questions are:
1. How do I choose which terminal blocks to use? I can see Screwfix has from 3A to 60A.
2. Does each core fit into a separate terminal block?
3. I'm assuming that there is no back box, so how can I secure the terminated cores and attach a blanking plate? (I need to remove the box).
4. Will I need an insulated screwdriver?
5. Is there anything else I have missed?
Any help would be greatly appreciated.
Re: Removing Surface-Mounted Socket from Skirting
by Mr White » Wed Sep 11, 2019 11:50 pm
Unless you plan to lift the floor boards so you can remove the cables, it would be easier to leave the socket where it is and cut a hole in the wardrobe, that way you can also use it to plug in a light.
If you really want to you can remove the socket, but it will cause a lot of problems, as you can't leave the cables just "sitting there" (Also you can not fit a blanking plate because as so you rightly said, there is nothing to fix it to) so that means lifting the floor boards to remove the cables, or installing a flush back box (That way you can then add a blanking plate)
If you do want to lift the floorboards don't use connector block use "wago" connectors as they are "fit and forget"
PieOfSauron
by PieOfSauron » Thu Sep 12, 2019 10:46 pm
Thanks for the info. I don't think fitting a back box into the skirting is going to be an option. Sounds like cutting a hole in the wardrobe is probably the best solution for this problem. I'll dig out the assembly instructions and see if this is going to be possible.
It is currently Sat Jan 11, 2025 12:47 pm
