Controls for Digital Radiator Playing up
Moth
by Moth » Sat Sep 14, 2019 10:00 pm
The controls on my digital radiator are playing up, and some not working so I can't adjust the temperature. Is it fixable, and if so worth it?
Re: Controls for Digital Radiator Playing up
by ericmark » Fri Sep 27, 2019 4:42 am
It would depend on make and model, I hate the word digital and smart because they can mean so many things, in theory digital is off/on so with electric heaters they are all switched off/on, but a standard thermostat will wear out quickly if it turns off/on every few minutes, so using solid state relays allows the manufacturer to reduce the time between the off/on cycles without the contacts failing so reducing the hysteresis, however there is no laid down description of digital so no way to work out what you have.
Many people seem to call a dial analogue and up/down buttons and a LCD display digital and it has nothing to do with how the heater works but only refers to the human machine interface.
Moth
by Moth » Mon Sep 30, 2019 11:58 am
Thanks for the reply. The heater is a Rointe series k, with an LCD display.
It is currently Sat Nov 23, 2024 3:28 pm
