Sealant for Shed Roofing Felt
Zacccc
by Zacccc » Mon Sep 16, 2019 1:29 am
I've just refelted my sister's apex shed roof. On one side of it most of the felt had been missing for a while so the wood had deteriorated. The roof needed 3 pieces, one for each side of it and a piece for the apex, which overlapped the other two. I used Black Jack felt roof adhesive. The felt was green, so when I brushed the black adhesive onto the wood at the apex and onto the two pieces of felt where they would be overlapped by the third piece I was careful not to go right to the edges where the apex felt ended because the adhesive was quite runny so I was trying to avoid a black line along the roof where the felts overlapped. I finished off by fixing the joints with clout nails.
Unfortunately, on the side where the wood had deteriorated the roof had sagged a bit, and now where the felts overlap, the edges haven't quite stuck down. Could anyone please recommend a clear adhesive, which I could use to stick these down.
I'm hoping that the black jack has adhered further up, away from the overlap joints and that therefore the roof will be protected from driving rain but I'd be happier if I could find something to stick the overlaps down at the edges. Thank you.
Zacccc
Clear Adhesive for Shed Roofing Felt?
by Zacccc » Tue Sep 17, 2019 11:41 am
Any suggestions or comments on clear adhesive would be welcome.
It is currently Fri Nov 22, 2024 12:26 am
