What Should I do if my Outer Drainage is Collapsed and Need to do Relining?
mrdrains
by mrdrains » Mon Sep 23, 2019 1:10 pm
Home drainage system are basically of two types internal and external. Internals drain is related to sink, bathroom, toilets and so on. These type of drainage system are properly planned and made a best setup for fault clearance. External drains are the outer drains which is connected with a main sewer pipe to carry out all the wast water of your home.
So if the external pipe gets collapsed then what we can do to get it ok.
It is currently Wed Dec 04, 2024 10:17 am
