Piggyback Joists to Extend Width of Loft Hatch
guitarwizard93
by guitarwizard93 » Mon Sep 30, 2019 10:54 am
Hi all,
I do apologise if this has been covered elsewhere, I did look but couldn't find my answer!
I need to extend my loft hatch ever so slightly to be able to accommodate a new ladder (and my shoudlers..). At the moment the hatch is just an opening cut between the joists, so is about 420mm wide. I only need an extra few inches width to fit the ladder, and that will also be sufficient to gain comfortable access.
A friend suggested that I secure a piece of timber to the outside of each joist on either side of the current loft hatch, and then cut out a length of each joist to give me the extra width of the now cut out joists. Does that make sense?
Is this a good idea? Will it be structurally sound if I use a a like-for-like size of timber and overlap sufficiently with what joist will remain? Is there a better/more efficient way to do this? If this is a good idea, are there any tips/tricks that I should note to make sure it's done well?
Thanks in advance for any input!
Liam
Raymondc
Re: Piggyback Joists to Extend Width of Loft Hatch
by Raymondc » Sat Jan 04, 2020 7:09 pm
Tricks of the trade help as im ten years in the loft ladder installation biz. First cut 2 timbers long enough to support your existing joists the ones you want to cut and extend. This will support your ceiling while you reframe your opening.regards
It is currently Sun Dec 22, 2024 9:22 am
