Connecting Replacement Motor on saw Bench
Simon Wray
by Simon Wray » Sun Oct 06, 2019 10:59 am
I have replaced the motor on my saw bench with a nearly identical motor. The new motor has a brake and therefore there is an additional wire. Where should this wire be connected?
I am confident with the standard wiring:-
Live = Red
Neutral = Blue
Earth = Yellow and green
The additional wire is white and I assume it should be bridged into one of the circuits, which will release/activate the brake.
Any help appreciated
Re: Connecting Replacement Motor on saw Bench
by ericmark » Sun Oct 06, 2019 10:10 pm
I had huge problems getting a motor brake to come on at the right time, it needs releasing before you power motor and applying after power removed and even with a PLC (Programmable logic control) I could not get timing right, and in the end swapped motor for one where it was all integral.
This is not some thing to be done with a forum, too easy to make errors.
by Mr White » Mon Oct 07, 2019 9:59 pm
What do the instructions say?
Simon Wray
by Simon Wray » Tue Oct 08, 2019 11:54 am
Hilarious. Thanks for your response
by Mr White » Tue Oct 08, 2019 7:13 pm
I was not being "funny" you have the motor, I do not.
All you have said is you have a motor and how do you connect it.
You have given no further information hence my question of what do the instructions say.
It is currently Sat Jan 11, 2025 12:48 pm
