Paint Stripping Stairs With a Heatgun but Possible Lead Paint?
zakqux83
by zakqux83 » Thu Oct 17, 2019 1:42 am
Image of partially stripped step below.
I'm very new to DIY so apologies in advance for any silly question.
I am using a heatgun (350c) and ffp3 cheap mask (£5). I plan on painting over once stripped. The step (for example central section back) has very tricky to strip small parts of paint, , is it worth leaving this and just sanding over? There is also material on the left and right sections of the step that is very hard to remove, not sure if paint or glue or anything tbh. Also worried it may be lead paint, are the "safety precautions" I've taken above sufficient?
Final question - does anyone have any idea what kind of wood it is?
thedoctor
Re: Paint Stripping Stairs With a Heatgun but Possible Lead Paint?
by thedoctor » Thu Oct 17, 2019 8:53 am
We have a project covering stripping lead paint that may be of some use to you that can be found here: https://www.diydoctor.org.uk/projects/s ... -paint.htm
In terms of timber, a bit hard to say but it's most probably pine
Kind Regards
It is currently Mon Nov 25, 2024 10:52 pm
