Exterior Wall Mounted Lights and Tapping into Existing Supply
Gooner100
by Gooner100 » Sat Oct 19, 2019 6:49 am
apologies in advance for the stupid question. We have recently moved into a new house and i need to fit several wall mounted lights to the exterior walls. There are wires and plastic tubing surrounding the wires on the outside of the house, running into round plastic boxes (which i believe are the waterproof boxes). However the lights only have a short amount of wire into a connector box. How can i connect the house wires to the connect box while maintaining the waterproofing?
Re: Exterior Wall Mounted Lights and Tapping into Existing Supply
by Mr White » Sat Oct 19, 2019 11:27 pm
I presume you mean the lights you propose to install only have a short flex?
The plastic tubing is known as conduit.
What are the cables in the conduit currently connected to?
A few pictures might help.
It is currently Mon Nov 25, 2024 12:56 am
