Replacing Aerial Distribution Amplifier
Stringy
by Stringy » Tue Oct 22, 2019 2:47 pm
I want to replace an old aerial splitter box with a newer one. Labgear LDA2081LR Distribution Amplifier
The old one looks to be powered by a cable connected to the lighting circuit. See photo
The new labgear has a 3 pin plug on it.
See photos of new splitter statistics and the old box connection
Is it ok to either :-
take the 3 pin plug off and wire in the new one exactly the same way as before?
or
replace the plate at the end of the lighting run with a 3 pin socket and then just plug in?
Re: Replacing Aerial Distribution Amplifier
by Mr White » Wed Oct 23, 2019 8:20 pm
You have to understand why the previous person installed a "clock socket" first.
As you said it is supplied by the lighting circuit. Lighting circuits are rated at 5 or 6 Amps maximum. So if you were to change the clock socket to a normal 13A socket, anyone could be tempted to plug in something higher rated, this would blow the lighting fuse/mcb as it would be drawing too much current, so to prevent this the previous person has installed a clock socket.
Your best option would be to remove the plug from your new aerial amplifier and replace it with the plug from the clock socket.
Also as its a clock socket, you just unplug it to change the cable to your new device, that way you can keep the lights on to see what you are doing.
It is currently Tue Jan 28, 2025 11:03 pm
