Hotpoint TDWSF83 Condenser Dryer Drum not Spinning?
lulworth
by lulworth » Sat Oct 26, 2019 4:58 pm
Hotpoint tdwsf83 bep condenser dryer
My drum wasn't spinning and the old belt hadn't snapped or stretched, I thought replacing the belt might solve the problem. (I definitely fitted the correct belt). There is a lot of slack on the belt and it won't tension. There is a black moulded part that appears to be attached to the motor housing which has a spring connection. The spring is in perfect condition yet when I move the arm the black moulded part won't tension the belt , it just returns as the spring drags it back, whilst I imagine it should possibly lock in to position,any advice would be appreciated.
It is currently Thu Nov 21, 2024 11:13 pm
