Overflow
7 posts   •   Page 1 of 1
jutt9
Overflow
by jutt9 » Sat Mar 24, 2007 5:07 pm
my toliet as an internal overflow but problem is after flushing the toilet the overflow doesn't stop. looked in the cistern and it just just keeps filling up with water and this can go on for hours.
anyone know what i can do to sort this out?
thedoctor
by thedoctor » Sat Mar 24, 2007 5:23 pm
Look at the project on cold water tanks, cisterns and valves it will give you an idea on how to stop water coming into cistern when its full
jutt9
by jutt9 » Sun Mar 25, 2007 3:43 pm
ok i checked the project. if i understand correctly it is the black rubber diaphragm that needs replacing?
am i on the right track?
thedoctor
by thedoctor » Sun Mar 25, 2007 5:54 pm
ts the valve mmdately nsde the cistern with the ball on the end of it. The ball lifts up with the water level and the arm of the valve closes it when its reached the required level. If this valve is not working water will just keep coming in.
jutt9
by jutt9 » Mon Mar 26, 2007 2:03 pm
the ball is lifting up but the valve is not stopping the water. is this valve available at DIY shops?
jutt9
by jutt9 » Fri Apr 06, 2007 8:16 pm
established that the valve is not working. can i buy a valve from a diy shop?
peter the plumber
by peter the plumber » Sat Apr 07, 2007 6:50 pm
Yes.
But remember to turn off the water before you start.
It is currently Fri Nov 15, 2024 8:58 pm
