Issues With Latest iOS 11.2 Update
Help and advice on software, hardware, configuration and general computing issues and problems
Mattlehat7
by Mattlehat7 » Sun Nov 10, 2019 2:38 pm
Anyone else had issues since the latest update? I am constantly losing connection, dropping calls and having incoming calls go straight to voicemail. Apple have been no help at all. If you are in same boat, I have found a bit of a workaround - in settings change from 4G to 3G. Obviously data speed is significantly reduced but I'm no longer missing calls. Hopefully apple will issue a proper fix soon.
It is currently Fri Nov 22, 2024 5:07 am
