Edwardian Flat Loft Cold Water Tank Ballcock
lennich
by lennich » Fri Nov 15, 2019 1:52 am
Ballcock valve leaking so I intended to replace the mechanism i.e.valve and ball with a part two version. Bought the part thinking all these are standard as every example I've seen on the web has a male connector.
Unfortunately I found that my very old tank had a mechanism with a female connector. I have been unable to source such a replacement. Anyone know somewhere I can get one?
Cheers,
Len
Plumbog
Re: Edwardian Flat Loft Cold Water Tank Ballcock
by Plumbog » Fri Nov 15, 2019 8:14 pm
Hi Len
Do you have any images of the existing one?
lennich
by lennich » Sun Nov 17, 2019 7:42 pm
[attachment=0]OldWaterValve.jpeg[/attachment]Hi
[quote]Do you have any images of the existing one?[/quote]
I do. I've taken the arm from a new part one device and replaced the washer. The old valve operates pretty much like a modern part one device except that the plastic cone thing which rests against the washer when closed is not present. A metal equivalent is a solid part of the water inlet pipe i.e.the pipe ends with a brass item soldered to the lead pipe. The brass item includes an inline valve to shut off water flow when working on the system.
Edwardian water valve
It is currently Wed Dec 04, 2024 9:44 am
