Connecting an LED Panel to a Wall Socket?
dscanlon
by dscanlon » Mon Nov 25, 2019 9:51 pm
Hi there,
I recently bought an LED panel, with the idea of fitting it into a cabinet to provide light while better using the space. The panel came with an LED driver - photos attached. I'm trying to figure out the safest way to connect the driver (which has 2 wires, one blue, and one brown) to a 13-wire, 13A plug? I'd be very grateful for guidance, if someone has tried similar before?
Thanks!
Re: Connecting an LED Panel to a Wall Socket?
by Mr White » Tue Nov 26, 2019 5:21 am
Why can't you not trim the wires length and fit a plug to the brown and blue?
If the flex is too short can you not lift up the blue section of the driver and replace the cable?
dscanlon
by dscanlon » Tue Nov 26, 2019 3:50 pm
Mr White wrote:Why can't you not trim the wires length and fit a plug to the brown and blue?
Well, I wasn't sure if it was that straightforward - this is my first attempt at a task like this :) Thanks for the tip though, appreciated.
It is currently Sat Jan 11, 2025 10:38 am
