Running Cabling for Induction Hob and Oven in Same Conduit?
Carnegie
by Carnegie » Tue Dec 03, 2019 7:23 am
I need to run separate 6mm T/E and 2.5mm T/E internal cables (for induction hob & oven) from fuse box in garage to kitchen - can these cables go together in white (non oval or circular) conduit, for fixing above skirting board, and, if so, what size & type of conduit? Length of each run approx 12 metres.
Re: Running Cabling for Induction Hob and Oven in Same Conduit?
by Mr White » Tue Dec 03, 2019 7:52 pm
No they can not go in conduit............because they will not fit.
You can however use trunking, but you would be better off with two smaller runs than one big run as its size increases in both width and depth as the size of the trunking gets bigger. (So you would end up with a huge square above the skirting, instead of two small oblongs.)
It is currently Sat Nov 30, 2024 4:40 am
