by ericmark »
Mon Dec 09, 2019 1:51 am
Simple answer is yes, the lock shield valve setting is important, but would not call it balancing in the old way.
I found the problem with a TRV is they are slow to move, so the temperature will over shoot, I found with liquid and wax heads it was a problem setting the lock shield as you simply don't know what temperature they are set at, marked *123456 is useless, I want to set to 20°C, then putting a thermometer in the room one can open or close the lock shield until the target temperature and current temperature are the same, I was using electronic programmable heads so it was showing both target and current on the PC.
So I moved my electronic heads around the while setting the lock shield, then once set moved them back to main rooms.
With the TRV on the feed it's not too bad, but with the TRV on return it is very important to slow the heating of the radiator to a speed that the TRV can close fast enough not to over shoot.
Even without this consideration unless set it is hard to reheat the house, with a modulating boiler the output can vary between around 8 kW and 28 kW. If the lock shield valve is left wide open, then the water will heat the closest radiator first, the hot return water will close the boiler down to around minimum output, as the TRV closes it will then force water through the next radiator, and so on, once all rooms are warm then the boiler will allow full output, but until all rooms are warm, the boiler will not give full output.
In theory there is no need for a wall thermostat, however in practice without the wall thermostat as the weather warms up the boiler will continually cycle off/on, so the idea is to fit a wall thermostat in a entrance level room with no alternative heating and no outside door which is normally kept cool. However in real terms that room rarely exists.
So using the hall clearly it has an outside door, so you need both a TRV and wall thermostat in the same room (hall) which was always against the advice given before the modulating boiler.
So idea is the TRV is wide open after the door has been opened so reheats the room fast, but before it reaches the wall thermostat temperature the TRV starts to close, so extending the time required to reach the last degree or two.
This also presents a problem, as if you change the temperature on the wall thermostat, you also need to change the temperature on the TRV, I fitted a Nest gen 3 thermostat and an Energenie MiHome programmable TRV which should have worked together, so as I should have set Nest, and the TRV should have followed, however it seems Nest has removed support, so I have to manually set the same schedule on both devices, which means I have a £50 TRV head where a cheap £10 eQ-3 programmable head would do same job, but in real terms not set exactly the same anyway, the long hall means heat takes time to travel along it, so the TRV is set to lift temperature at 7 am, but the wall thermostat raises temperature 0.5°C per hour for 4 hours or it will over shoot, but mainly that's because my boiler in this house does not modulate as I am using oil.
So I have a wax TRV in shower room, no TRV in bathroom, 4 MiHome TRV heads in living room, dinning room and hall, and a eQ-3 head in kitchen as it has open window function so when I unload shopping it auto turns off heating.
Upstairs another 4 eQ-3 heads in my case the more expensive blue tooth versions at £15 each. Although I will admit once set I don't really use the blue tooth, I simply press the comfort/eco button to swap between 17°C and 20°C when I enter a room, and can also press the boost button if I want a fast warm up.
So if you maintain your house at the same temperature day and night and never turn off heating in winter you could get away without setting the lock shield valve, but if you change temperature through the day, then the lock shield needs setting.
