Tanking the Cellar Walls and Floor for Dry Storage Space
6 posts   •   Page 1 of 1
VictorianTrouble
by VictorianTrouble » Sun Dec 15, 2019 1:00 pm
We’ve recently decided to tank the cellar and convert it into a dry storage space that’s not too cold.
The floor is bricked and the walls are currently painted. I’ve been running a space heater and a dehumidifier for a few weeks now. The place is drying up slowly.
However, the next challenge is to tank the walls and the floor. I’ve decided to use tanking slurry instead of a membrane because there’s no place to install a sump and pump. My main concern now is the mortar between the bricks seem to be lime based and it’s deteriorated quite badly. The bricks on one wall are also very damaged and has a powdery surface.
Can someone please advise me on whether I need to replace the bricks and mortar before applying the tanking slurry. I was thinking of applying a layer of sbr before applying the tanking slurry on the walls and then the floor.
I’ve attacked some pictures. Any advice would be much appreciated.
thedoctor
Re: Tanking the Cellar Walls and Floor for Dry Storage Space
by thedoctor » Sat Dec 21, 2019 9:23 pm
All holes of any kind in walls need to be 100% filled with a 4 / 1 sand cement mix before the slurry is put on.
More information on tanking can be found in our project here: https://www.diydoctor.org.uk/projects/tanking.htm and also in this project: https://www.diydoctor.org.uk/projects/u ... oofing.htm
We also have a video on youtube that you might also find useful: https://www.youtube.com/watch?v=WdAqnJDRjHM
Hope this helps
VictorianTrouble
by VictorianTrouble » Sun Dec 22, 2019 9:30 am
Thank you very much for the video.
thedoctor
by thedoctor » Sun Dec 22, 2019 9:01 pm
No problems, glad to help. Good luck with the project
KInd Regards
VictorianTrouble
by VictorianTrouble » Sun Dec 22, 2019 10:52 pm
The floor is very uneven. Is it best to apply a self levelling concrete then tanking slurry or the other way round.
thedoctor
by thedoctor » Mon Dec 23, 2019 8:49 am
Yes, level the floor first and then once all cured, crack on with the tanking.
We also have a project page on levelling floors here that may help: https://www.diydoctor.org.uk/projects/l ... floors.htm
Kind Regards
It is currently Fri Feb 07, 2025 1:42 pm
