Very Slow Trickle From Bathroom Basin, Can't Check Cold Water Tank
Yes
by Yes » Sun Dec 29, 2019 12:20 am
Slow trickle from cold water tap in bathroom basin but not able to check cold water tank in loft or remove tap as disabled pensioner, any advice on a fix?
stuartb3502
Re: Very Slow Trickle From Bathroom Basin, Can't Check Cold Water Tank
by stuartb3502 » Wed Jan 01, 2020 10:39 am
If cold taps and toilets elsewhere working OK, then I'd suggest the problem may lie in the tap itself. You don't say whether this happened suddenly or over time.
I have a tap which has just gone to a trickle after a leak was repaired nearby - I suspect debris has found it's way into the tap and partially blocked it.
It is currently Thu Nov 21, 2024 6:40 pm
