No hot water
Rebecca
No hot water
by Rebecca » Tue Sep 11, 2007 5:40 pm
I have a Halstead Ace Boiler, the central heating works fine but the hot water won't come on. Any suggestions!!!!!!
by htg engineer » Sun Sep 16, 2007 6:55 pm
Could be a few problems
diverter valve stuck
diverter diaphragm split or stretched
faulty microswitch
Without knowing what you're doing, you'll struggle to diagnose the fault yourself. Call a heating engineer to take a look.
My guess would be the diaphragm in the pressure differential valve has split. If you know what / where on the boiler this is, you may be able to do some more checks. Let me know.
if i can help anymore i will
