cutting tiles
give it a try
cutting tiles
by give it a try » Tue Sep 11, 2007 7:05 pm
hi i bought a 2nd hand tile cutter that wont cut the line straight anymore, i'm not sure what make it is, but want to buy new one, and not sure what make to go for?
DUDE DIY
by DUDE DIY » Fri Sep 28, 2007 5:10 pm
Hi there. hope my advice helps. I can only assume your cutting bathroom or floor tiles?...and also assume you bought a manual tlie cutter?...If this is the case then forget the manual cutter. I strongly recommend buying an electric wheel tile cutter, you can pick these up for as little as £30 now and will make your life easyer. Plus you will get a better final result...its a must have if your tiling. Dude diy
It is currently Sat Nov 23, 2024 6:51 pm
