Paint Blistering Problem That Reoccurs Every Year (With Photos)
GeoffH
by GeoffH » Tue Jan 07, 2020 5:02 pm
My first time here.
I have a problem which recurs every year. Paint blisters on an interior wall. I've painted the exterior part of the wall with silicone brick sealer, scraped off all the blisters, painted the whole wall with Zinsser BIN, filled the damaged areas and repainted, but the blisters re-appear after a week or so.
It's just on the pillar in the photos and not on the pillar on the opposite side. This side does get a lot of rain and the same wall in the flats above have the same problem.
Someone told me it could be efflorescence, so I treated with wine vinegar solution, sealed and repainted but still not solved.
Any thoughts?
Geoff
Blisters 2
Blisters 2
Lower Corner of Wall by Skirting
Blisters
Blisters
Pillar
Pillar
chaz57
Re: Paint Blistering Problem That Reoccurs Every Year (With Photos)
by chaz57 » Wed Jan 29, 2020 12:25 am
you nailed it in one . efflorescent. better to plaster board over
thedoctor
by thedoctor » Wed Jan 29, 2020 8:36 am
It does indeed look like efflorescence - We have a project page that covers the causes and also cures for efflorescence that may be of use to you: https://www.diydoctor.org.uk/projects/e ... -cures.htm
Kind Regards
GeoffH
by GeoffH » Thu Jan 30, 2020 1:33 pm
Thanks both for your replies.
I can't plaster board over it, though I can see the advantages. To do so would make the wall too thick for the door frame and window frame.
I have previously painted the exterior wall with silicone brick sealer so I thought this would stop any water coming through the brick. However, I have since discovered the window frame is a bit rotten and may be letting water in the edges of the frame.
Is it necessary to use the special salts neutraliser, or does the wine vinegar solution work as well? I have Zinsser BIN which I can use after that to cover the damaged areas.
Thanks for your help.
Geoff
It is currently Mon Nov 25, 2024 12:49 am
