Tiling Over a Wooden Floor and Self Leveling Advice
borr22
by borr22 » Wed Jan 08, 2020 1:02 pm
Hey everyone!
Im tiling my kitchen and lounge, the lounge is 5m x 5m and is a wooden floor with a RSJ support in the middle and the kitchen is 3.8m x 2.7m but is a concrete floor.
The joists in the lounge have been reinforced by sistering the joists and installing noggins.
The kitchen is 25mm higher than the lounge with 22mm P5 T&G particleboard installed.
I want to tile the whole lounge and kitchen with 600mm x 600mm porcelain tiles.
The water-resitant particle board hasnt been installed yet, it has just been laid down for the plasterer so it can be changed if needed.
My plan was to:
Install the particle board
Use a cement board backer board on top
Use self leveling compound with a wire mesh to bring the lounge to the height of the kitchen
Install a ditra membrane for both the kitchen and lounge.
Use a flexible tile adhesive
Then tile
It is currently Sun Dec 22, 2024 4:08 am
