Continuous Water Flow From Mira Sport When Shower Turned off
Tugster
by Tugster » Tue Jan 21, 2020 9:29 pm
We have a Mira Sport 9.8 kw. Had a problem with the shower running cold. Replaced Thermal switch & shower heated up fine. However when we turned it off by switch it continued to run. Looked up fault diagnosis & so far have replaced Thermal switch, Switch Assembly, Flow Valve & Solenoid. Still didn't fix it. A relative has exactly the same shower so we borrowed that one & plumbed it in. It's doing exactly the same thing. The water flow just doesn't switch off. Too much of a coincidence that a perfectly fine working shower would suddenly have the same issue. Anyone shed some light on this?
It is currently Wed Dec 04, 2024 10:05 am
