Improving Pressure in Direct Heat System in Flat
ricardo100671
by ricardo100671 » Tue Jan 28, 2020 9:22 am
My flat suffers from poor mains pressure and we have a direct heat setup with combi boiler.
The boiler is rated up to 3Bar, so I was thinking of installing a cold water tank to feed a twin pump supply cold and into the boiler for hot (both 15mm).
My questions are
Is this a feasible setup
Can I use a single 28mm feed from the tank to a double 15mm manifold into the pump or should I install two 22mm/15mm feed pipes from the tank instead.
Thank you in advance for any help you can offer.
It is currently Tue Dec 24, 2024 12:26 pm
