Stone Tiles on Wooden Floor.
robcrabb
by robcrabb » Wed Sep 12, 2007 2:39 pm
I need to lay some 4" stone tiles on a wooden floor with ply wood on it.
Grout and Adhesive - I cannot find a combined grout and adhesive for this application in any colour but grey! Does one exist in white/ivory etc?
I am told that the ply wood must be a minimum of 12mm thick with 300mm centres screwed down - is this true?
Please help!
Thanks :?
gam
by gam » Thu Sep 13, 2007 2:20 pm
hi Rob,
You should use separate adhesive and grout both available from topps,
Also just make sure that the wood/ply is secure,
you may want to add some mix to the grout to ensure is flexible.
Good luck
Gaz
Skunkfu
by Skunkfu » Fri Sep 14, 2007 4:17 pm
Like gam said you need separate tile adhesive and grout.
Your tile adhesive [b]must[/b] be flexible too, not just grout if you dont want to redo everything in couple months.
It is currently Tue Nov 26, 2024 4:13 pm
