HELP NEEDED WITH TRIPPING LIGHT
inrunning
by inrunning » Wed Sep 12, 2007 5:30 pm
I've fitted a new light placed the wires hopefully where there are supose to go checked and rechecked for mistakes but am still having the same problem.When the light is switched on its fine but as soon as i turn it of it trips out the fuse.Any help would be much appreciated.
BLAKEY1963
Re: HELP NEEDED WITH TRIPPING LIGHT
by BLAKEY1963 » Fri Sep 14, 2007 7:44 pm
[quote="inrunning"]I've fitted a new light placed the wires hopefully where there are supose to go checked and rechecked for mistakes but am still having the same problem.When the light is switched on its fine but as soon as i turn it of it trips out the fuse.Any help would be much appreciated.
Thanks[/quote]
INRUNNING
THINK U NEED TO GET HELP WITH THIS ONE
by sparx » Sat Sep 15, 2007 6:33 pm
Hi, R U sure you're tripping when switching 'off'?
If U have done the classic co*k-up & put all reds together & all blacks together, then light will come on with sw. in 'Off' pos, & will blow due to putting sw. as dead short across supply when turning 'On'!
Check with Docs project section for correct wiring
It is currently Mon Jan 13, 2025 4:55 pm
