Extractor Electric Motor Case Welded
mauroercolini
by mauroercolini » Mon Feb 24, 2020 5:22 pm
Hi, new to the forum. I hope someone can give me a tip.
I wanted to service my extractor electric motor, as it wouldn't spin anymore, and I cannot take the outer case apart. It's like they've been wleded together. Has anyone seen anything similar?
thank you
Mauro
Re: Extractor Electric Motor Case Welded
by ericmark » Tue Feb 25, 2020 12:01 am
I have managed to lock the ball shaped sintered bearing and free them on the shaft and re-lubricate them. But often they start to rotate in the housing instead of shaft, and only cure is replace whole motor.
With some thing like a Myson fan assisted radiator it is worth the effort, but with extractors it is not really worth the effort just replace whole thing.
by Mr White » Tue Feb 25, 2020 5:21 am
If you mean an extractor fan, the case probably has been ultrasonically welded as they are non serviceable and its cheaper to buy a new one.
mauroercolini
by mauroercolini » Tue Feb 25, 2020 7:54 am
Hi Mr White, thank you. yes, that's what I meant. too bad I can't find one anywhere...
It is currently Sat Jan 11, 2025 7:51 am
