Push to Close Switch Extractor Fan
Berserker
by Berserker » Tue Feb 25, 2020 11:47 am
I hope I'm not missing the obvious but is there such a thing as a push to close switch that returns when released. I have a extractor fan unit that has a humidity sensor and timer. The humidity sensor will take care of turning on when its needed to remove moisture so this is more for smells, I hate a fan being on when the light is on so I want a switch to trigger the fans internal timer but to auto release so it doesn't stay on if you forget to turn it off.
John
Re: Push to Close Switch Extractor Fan
by Mr White » Tue Feb 25, 2020 6:53 pm
Yes there is such a switch, its used for door bells. No, I don't mean a normal door bell button, you can get bigger plate switches that are for "door bells"
Berserker
by Berserker » Wed Feb 26, 2020 11:44 am
Awesome thank you found those, it's on order now :-)
It is currently Sat Jan 11, 2025 7:06 am
